Hey all, thought I'd give a quick build log of the KKSB Mini ITX Case that I reviewed after backing their Kickstarter campaign.
First of all this is a link to the case
KKSB Mini ITX Case
Specs for the build:
CPU - Ryzen 5 3600
CPU Cooler - Thermalright APX-90 full copper, with a Noctua NF-A9x14 Chromax
Motherboard -Aorus X570 I Pro Wifi
GPU - nVidia RTX 2070 Founder Edition
Ram - 16GB Corsair Vengeance LPX 3600Mhz
PSU - Corsair SF750
Storage - 2 x 1TB 2.5" SSDs and a Corsair P1 M.2
The build process was pretty straight forward for this case, it's very similar to other sandwich style cases, with the only minimally frustrating part involving getting the PSU bracket back into place.
The build quality of the case is very good! All the panels are sturdy and perfectly machined, there are no rough edges and everything lines up as it should when put together. They also include 2 x 60mm fans in the bottom of the case (set up add intakes).
Out of the box you get a full colour instruction manual (really nicely printed and easy to follow), a fan splitter, SATA extension cables, an allen key (the screws that hold the side panels and 2.5" drives are hex head) and as mine was from the Kickstarter campaign I also received the optional glass side panel and spacers.
Imgur album link KKSB Mini ITX Case Build
I'll run some temp tests and add them soon.
KKSB Mini ITX Case
CPU - Ryzen 5 3600
PSU - Corsair SF750
