VegetableStu
1,949
2,619
i really want the x399m, but after a cursory sanity check it’s either a 140mm aio or the noctua TR4 U9S. maybe even a higher wattage PSU as well
dammit I need to get to sleep
EDIT: There's the Arctic 33 Freezer TR though. 120mm fans and (hopefully within margin of error) 155mm in height (that's about the height with the side bracket removed)
https://www.arctic.ac/worldwide_en/freezer-33-tr.html
MarcParis
Apr 1, 2016
3,627
2,721
Cerberus owners rejoice!
We finally have an mATX x399 motherboard
https://videocardz.com/74600/asrock-shows-off-x399m-taichi-microatx-threadripper-motherboard
News post coming soon!
Mini ITX X399 is near..:D
Reactions: Elerek and cmyk78
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
Hmmm... how to fit the largest amount of radiator into the Cerberus X?
A 280mm on the bottom might be doable, a 280mm on the front too probably not (even if the rad would fit, I'd expect you'd hit interference problems once you add fittings and fans). A 280mm on the bottom and 240mm at the front might work, or would interference still rear its head and require 240mm for both locations (or a 280mm at the bottom and 140mm on the front)?
A suitable pump is also tricky. Other than gutting an AIO to run things (and those slim enough to fit under a rear-mounted SFX PSU are either not intended to be modular, or out of stock like the Fractal Kelvins or the original Swiftech H220), standalone pumps are either quiet but huge (PWM Laing D5 variants), small but noisy and a bit feeble (DC-LT variants, which many AIO pumps use too), or apparently unavailable outside the US (e.g. Swiftech MCP50X).
Chann3l
78
68
If you do a rear mounted PSU you might get away with using a fan mount bracket for the reservoir and use a short res D5 or ddc combo mount to the upper fan on the front rad.
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
I was intending to skip the res entirely, not much reason to include one other than aesthetics and to make filling a bit easier.
wywywywy
272
219
Hi guys, got a couple of questions.
1. Has anyone done a full custom loop in this yet? A full custom loop not an AIO.
2. When using an mATX board, is there still enough space for a 280 rad at the bottom?
Thanks.
Taswegian
89
76
I guess a nice compromise could be made by just making sure the loop has enough slack to route to a suitable high point and install a T fitting for easy fill / bleed ?
Winterheart
Thanks.
1: Yes, I've got a full custom loop in my Cerberus, comprises a Strix Z370-I mobo with full cover block, Zotac 1070 Mini with Alphacool block, EK SE240 radiator in front mount config with dual Noctua 120mm Industrial fans, EK SPC-60 pump/res combo.
2: unfortunately not able to help you on this one as I'm using an ITX board not MATX.
I will be redoing my rad later this month with a bottom mount EK XE 240.
KSliger
Sliger Designs
May 8, 2015
855
3,186
Hey @KSliger, how high is the mobos standoffs? is it 0.12' or 0.18"?
Thanks, man.
.265" from bottom of mount pad to underside of motherboard. Not sure either of those posted will work.
Will add threaded uATX standoffs to Cerb X for revision.
-Slightly off topic: Was wondering if there was any way to just purchase the machined handle?
Adding to website shortly =]
Crysilus
23
Have any pics of your setup?
KSliger
Sliger Designs
May 8, 2015
855
3,186
If anyone has a picture of their build they'd like featured on the official case product page please PM me! (Will link to your post or cite credit to you either user name, forum name, or can leave anonymous)
Goes for both Cerberus and Cerberus X
neojonathan
Hello ! Just a few questions about this beautiful case. Would it be able to fit a ASUS Strix 1080 in this case without any cable interference?
Taswegian
89
76
Seems like it should fit.
That card is apparently 134mm high and the Cerb cases have 152mm PCIe clearance so it looks like you should have enough room above the card for the power connectors.
