Closed JUBO / VIEWNOTE A300 Thin Mini ITX Motherboard / for RYZEN 4000 APUs (RENOIR)
Selling my VIEWNOTE A300 Thin Mini ITX Motherboard from one of my previous projects.
The board is compatible with RYZEN 4000 Series APUs (Renoir) only (not 3000 / 2000), supports dual channel DDR4 RAM and M.2 SATA or NVME SSDs. It works with 12VDC - 19VDC.
Asking for: USD 65,- // EUR 60,- plus (worldwide) shipping via UPS
I'll throw in a suitable very low profile OEM cooler for free!
Goatee
720
1,488
Hmm, your leading me into temptation.....
What would be the damage with a 4650G....
BaK
855
868
No 4000 serie CPU listed here: http://www.viewnote.cn/pro_article.aspx?id=1344
But I see more compatible CPUs here, 4000 included: https://www.alibaba.com/product-detail/Viewnote-AMD-A300-AM4-itx-motherboard_1600101371576.html
How come? Not the exact same mobo than yours?
I'll throw in a free 19V 130W internal OEM PSU!
How is it supposed to work? The 4pin looks like to be 12V and I don't see any other input option besides the external 19V.
Any clue if wake-on-lan is available?
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
There are different BIOS versions for that board and they sell it under different names. Since the BIOS size is max 32MB it supports either 4000 Series APUs or with another BIOS the 2000 and 3000 series APUs.
It works. The board supports a wide input range 12 to 19V DC, both via internal 4PIN header or external brick.
Reactions: BaK
BaK
855
868
After chasing JUBO for quite a few month now sending me an BIOS update to add support for Renoir on my JUBO A300 Thin ITX they finally did it!
They are now offering two versions of the board with different BIOSes:
  • Option 1: Ryzen 2nd and 3rd GEN APU support
  • Option 2: Ryzen 4th GEN APU support
Does that mean you can provide both BIOSes?
Is there a manual online of that motherboard, in english preferably?
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Unfortunately they dont provide the BIOS files. But JUBO provides a flashing service.
Not that I know of. Only the product description on TaoBao.
