Hi friends!!!
Some weeks ago I finished my last built...
HARDWARE:
Raijintek Ophion EVO
Asus ROG Strix X470-I Gaming
AMD Ryzen 7 2700X
Ballistix Tactical Tracer RGB 16GB DDR4-3000 (x2) 32GB
KFA2 GeForce® RTX 2080 OC
M.2 Samsung 950 PRO 500GB
SSD Samsung 840 EVO 750GB
HDD WD Green 3TB (External)
Corsair SF600
Logitech G710+
Logitech G502 Hero
Corsair ML120PRO (2 above + 1 bottom)
W10 Pro
HP 20" (temporary)
And in a few weeks I would like do a revision and change from air to liquid cooling. Soon:
CASE CHANGES:
- Reijintek OPHION EVO aluminim side panel set [RECEIVED]
- Demciflex dust filter 280 ID [RECEIVED]
- Mod to side panels, will be soon [REDACTED]
COOLING CHANGES:
- Corsair Hydro Series H100i RGB Platinum [RECEIVED]
- Corsair ML120PRO RGB for change bottom fan [RECEIVED]
- Pin rivet for 140 fans and dust filters [RECEIVED]
- Silverstone SST-FF123B for bottom case [RECEIVED]
WIRES CHANGES:
- Connectors from Moddiy [RECEIVED]
1 x modDIY ATX 24 Pin Female Connector Housing (Black)
4 x modDIY Standard 4-Pin Female Connector (Black) with Pins
1 x 8 Pin Motherboard Power Female Connector with Pins Black
2 x 6+2-Pin PCI-Express Power Female Connector w/ Pins - Black
4 x 5 Pin SATA Connector with Pins Black
2 x Premium High Speed SATA Data Cable with Latch (10/20/30/60/100cm)(Length: 20cm)
1 x Corsair SF600 SF450 SF Series Modular Connector (Full Set 7pcs)(Pin Type: Standard Pins)
2 x Premium Stealth Computer Closed Cable Combs (4 Colors / 9 Types)(Type: 24pin (Motherboard))
2 x Premium Stealth Computer Closed Cable Combs (4 Colors / 9 Types)(Type: 12pin (6+6pin GPU))
CHANGE MONITOR (options):
- LG 34GK950F-B [...]
- ALIENWARE AW3418DW [...]
After this I have more ambitions and revisions for this project... But, I must finish this first
You can see full gallery here
