I haven't seen many Jonsbo A4 PC builds in the wild and there are even fewer watercooled builds out there.
So I figured I might aswell share my experience so far. It still is work in progress as I'm waiting for the new Nvidia RTX 3000 series to launch.
There we are. The Jonsbo A4 case seems to have good dimensions for nice looking watercooled builds. However, I had to drill some holes into this case. One hole for the drain port and one hole for widing out the top panel so I can use the radiator plug as a fill port.
I'm yet to figure out how to add pictures here.. ?
