The NH-L12S is a mere 4mm too tall to fit in the Ghost S1:
https://noctua.at/en/products/cpu-cooler-retail/nh-l12s
It is 70mm tall, but the case only allows for up to 66mm. Here is what the RAM clearance looks like:
Looks like if you used RAM without head spreaders there would be ~2mm clearance, which isn't the 4mm we need. But if you used some naked VLP (Very Low Profile) RAM, that would change that ~2mm clearance to ~14mm.
I think it might be possible to build a jig that could be used to "squish" the L12S down by 4mm without damaging anything. Then it would fit in the Ghost S1 just perfect. Also, that brings the RAM clearance down from ~14mm to ~10mm, potentially allowing you to switch from a 15mm to 25mm fan width. (Assuming those heat pipes are not in the way).
As far as I have seen this would be the best possible air cooling for the S1.
Thoughts?
Thoughts?
