Does anyone know of a case with similar orientation to the bitfenix portal case where PSU is at bottom and GPU at top?
The only other case I found is the GEEEK MX110 which does not have feet to allow airflow to bottom of case for PSU and also lacks side ventilation and is overall cheap plastic quality.
bitfenix portal looks awesome but IMO the top panel should be mesh and sides should be ventilated.
would be awesome if someone on sff forum is custom building a case with this layout.
Swapping the PSU and GPU could also work though the PSU fan should be facing up to a vented mesh and bottom should have clearance with mesh for GPU.
