ITX case that can be mounted behind the monitor?
RedArt
24
Has anyone found any case that can be mounted behind the monitor?
I would want to make a system with the new Ryzen Apus but dosnt look like you can fit a standard mini itx...
So far I only found two from Silverstone that do the job but one (VT01) is only compatible with intel mini-stx and the other (PT13) works only with thin mini-itx. ( Generally the others want Intel NUC MB)
I was even looking at the InWin Chopin but that looks too big to be mounted with the VESA standard.
Any idea?
RedArt
24
You cant put a SKyreach 4 mini behind a monitor on a VESA mount. How small are you thinking about going?
The smaller the better for me. The skyreach provides the space for a videocard which I dont need so Im seeking something smaller like this: http://www.silverstonetek.com/product.php?pid=419
Realan has a quite a few Mini-ITX cases in either aluminum or steel to choose from and also supply the VESA mounting hardware for those cases (L02 for aluminum and L01 for steel).
Thanks, they look like have plenty. Only problem I see is that you can only order from china and you cant find any in retail stores :S
Reactions: Soul_Est
RedArt
24
Mini-Box M350 also support VESA
Thanks for the info that would probably actually work. From their site I see they sell a Display Wall Mount Kits, I dont get If I need that or you can even just use the screws that you linked me.
Adding to the M350 mentioned by @Vlad502 , there is also the Morex 557, the MX500, and I think the MC500 from Logic Supply can also be VESA mounted.
Thanks for the suggestions. Like the other one this can do the job. Only problem im finding for both is the availability for me. In the EU isnt easy to find them.
Vlad502
256
206
If someone like me is interested in the subject and is located in the EU, I found out that all Realan cases are available here but rebranded:
https://www.inter-tech.de/en/products/case/mini-itx-nuc
JX-500 looks interesting. Maybe with some modding (PSU replace) is possible brickless system
Reactions: Jello
RedArt
24
You know isnt the first time that I read people talking about changing the original psu in these cases. Is there a reason for that? (im not too aware about quality on these)
You could also put a NUC on there, intel makes several:
https://www.intel.com/content/www/us/en/products/boards-kits/nuc/mini-pcs.html
for some reason the Skull Canyon/Hades Canyon aren't on that list, but they're available also.
You know I would rather go with a Ryzen APU on a custom build instead of a Nuc system where usually everything is limited or expensive.
DarekLogic
Logic Supply
Jan 13, 2016
42
105
www.logicsupply.com
Thanks for the shout out @Jello.
Hey @RedArt, just popping in to mention that we have an EU office (located in The Netherlands) that serves Germany if you were interested in checking out the MC500 - https://www.logicsupply.com/eu-en/mc500/ or the MC600 - https://www.logicsupply.com/eu-en/mc600/.
Reactions: Jello
RedArt
24
Thanks for the infos. The 600 is far too big for a VESA mounting, the 500 looks ok but can the page dosnt say it supports vesa does it? Does that office serve all EU or only Germany?
Antec ISK110 VESA
This one looks interesting thanks. I read some review that says his power brick sucks, do you happen to have any info about it? (maybe u own it idk)
DarekLogic
Logic Supply
Jan 13, 2016
42
105
www.logicsupply.com
Duality92
307
330
built a customer rig in one once, that's it.
