Enclosure ITX case I can vesa mount to a monitor?
Damprol
Is there a case designed to be mounted to the back of monitors that is capable of housing an ITX motherboard along with an HDPlex 400w DC-ATX board?
tinyitx
2,112
2,082
Perhaps a Silverstone Milo 10 might come to a close fit?
You will have to figure out how to fit the power supply part.
And, InWin Chopin and Gamemax S103. Check these out as well.
threestripevida
273
464
The only case that I know of is the S4M-C (There might be others that I don't know about tho). The newer Skyreach mini should be able to do the same, but I'm not entirely sure.
Dem0nflare
34
ASrock desk mini has vesa built in and comes with a power brick. Might be easier to just get a custom side panel made with vesa mounts for a K39 or a Skyreach. Velka case might be a option too once the side panels have holes in them, as-long as two holes line up with vesa. I would also say HT5 or the Smaller Geeek case but idk how acrylic would hold up.
