Looking for an ITX case that has good air flow (enough for a little overclocking headroom for Ryzen), doesn't have the GPU too close to the side (like maybe 3-slot support), and a glass side panel/window. Support for 240mm+ rad/s would be nice, but I might air cool everything too so about 80mm+ of space above the CPU would be nice as well. I'm looking for something under $100, but $150 isn't out of the question if it fits the requirements.
I'm looking to make a <$1k build, so custom water pipes and pumps are out, but AIO's or air coolers aren't.
Coolermaster Q300L is okay, but doesn't have good air flow, and I'm not sure if it's small enough.
Thermaltake Core P1 looks great, but I'm not a huge fan of the open-air style.
Thermaltake Core X1 seems solid, but I don't like acrylic panels (durability is important), and cable management is not good.
Phanteks Evolv Shift comes close, but air flow doesn't seem good, and you can't see the front of the GPU unless you get a custom riser cable.
Metallic Gear Neo G (specifically the MG-NE210G model) looks awesome and might fit all my requirements, but I haven't researched it enough, and I'm not sure what the size is like. I do like the convenience of the full size PSU (as opposed to SFX), and I love the vertical GPU layout, but like I said, I don't know a lot about the case.
Slinger SM650 would be great, but it's a bit pricey and I would like to be able to see the motherboard through the glass.
Any other suggestions?
