The problem is when I start my PC with windows 10, the windows logo comes up, I don't get the moving circle probably because of a fast boot up, which is considered normal, then I get the photo, by default it's the Windows 10 mountain and river photo, during the photo screen after 2-3 seconds it starts to flash once to a black screen (approximate 1 second) then back to the photo, it happen with a HP 16:9 monitor that I started to use yesterday, coming from a 4:3 Philip monitor which I used before then and it didn't have this problem. Both Monitor are not new, and connected using a OEM HP mDP to DVI Adapter and OEM HP DVI Cable.
Is this a problem with the refresh rate of the HP Monitor or is it something else. My full setup is the following
Ryzen 1600 CPU
Gigabyte AB350N Gaming WIFI m-ITX
Gskill Trident Z RGB 16GB AMD edition
Samsung 512GB 950 Pro SSD
AMD Radeon Pro WX3100
Silverstone SX700PLT PSU
Seagate 4TB for storage
Water cooling
Ryzen 1600 CPU
Water cooling
