Image Credit - Baidu​
It seems that info about Intel's 12th Generation NUC has surfaced on the Baidu forum. The Serpent Canyon NUC will be powered by an Intel I7-12700H and Arc A770M mobile GPU. The I7-12700H features 6 performance cores and 8 efficiency cores. and is a 45 watt part. The previous NUC (Phantom Canyon) used an Nvidia RTX 2060 as its GPU. This time, Intel will be going with their home grown silicon. The A770M features 32Xe core, 32 Ray Tracing units, boost clocks of 1650mhz, and up to 16GB of GDDR6 memory on a 256bit bus. It's rated between 120 to 150 watts of power.
The Serpent Canyon NUC has grown to 2.5 liters in size as compared to the 1.3L Phantom Canyon, and can be mounted vertically or horizontally.
Ports include a Thunderbolt 4, card reader, USB 3.2 Type-A, 3.5mm Audio, HDMI 2.1, and Display Port 2.0. Wireless is unknown but there is a 2.5GbE ethernet port.
You can check out the Baidu thread by clicking HERE.
Credit to VideoCardz for breaking this story. Check out their site, and original article, by clicking HERE.
INTEL-NUC-12-Serpent-Canyon-ARC-A770M-5.jpg INTEL-NUC-12-Serpent-Canyon-ARC-A770M-7.jpg INTEL-NUC-12-Serpent-Canyon-ARC-A770M-2.jpg INTEL-NUC-12-Serpent-Canyon-ARC-A770M-3.jpg INTEL-NUC-12-Serpent-Canyon-ARC-A770M-4.jpg
5,570
4,778
That vertical mount is such an uninspired piece of crap, while featuring in the hero images.
