Installing 3x HDD (with RAID?)
BReese8675
Hi, planning on ordering this case soon. I have 3 10TB WD Red drives, and was wondering how easy it is to use these in the M1.
I know you can easily use the HDD bracket and install 2, but how about the third? Is there a way to put one up front where the SSD would go?
Plan on either doing RAID 1 with 2 drives or RAID 5 with 3, plus have a backup on the Cloud. Gonna be a sick Plex server.
Thanks!
smitty2k1
936
473
It really only fits two 3.5" HDDs depending on your hardware configuration. If you have a short enough CPU cooler or a small enough GPU you can certainly fit more. Do you know what CPU cooler and GPU you will be using?
The front of the case only fits 2.5" drives.
BReese8675
I misread the website specs, I see you're right, only 2 3.5" are possible. Thanks!
Amonchakai
99
36
If you don't use a dedicated GPU, there may be some more options. (like put them on the bottom of the case)
