Cooling i9's with a 120mm AIO?
Seki
Hello my name is Seki, So I am in the process of potentially building a more workstation computer (rather than gaming).
And I saw the Mjolnir case... which is perfect for what i want.... however only supports 120mm AIO.
I need the x299e itx format for the 4 sticks of ram... I need a minimum of 64GB.... (unless you guys can point me towards an another ITX motherboard with 4 DIMM Slots)
I was considering a 7th gen skylake-X so i can delid it... however the 9 series have soldered chips which are in comparison from what I have read, only 3ish degrees higher, And i dont void warranty.
I noticed the Corsair Pro i180 uses a slightly bigger than 120mm radiator for there build, hence why I am considering the 9920x more than anything else...
Any advice on an i9 with 120mm AIO?
Thank you so much for reading this post, any help is appreciated!
