I think I found the right place
I could be summarized as a fulltime front/back-end web developer, with a 3m long desk, and two 900D's; working on my first(if we don't count the Node 202 and a 250D) four M-ITX Systems, all at once, with one of them nearing completion.
In the following months, you can expect the following:
[begin]
-Hardware[Private]:
--CPU:
---Model === i7 8700k && i9 7900x && R7 2700x => Performance & Sub-Profession-Specific Requirements
---Overclocking.Core === true => Synchronous Tasks
---High Core-Count === true => Virtualization & Multi-Threading
--GPU:
---Model === Titan XP && 1080 Ti[Unlocked] && Vega 64 => Performance && Compatibility-Testing
---Overclocking.Core === true => Hobby-ism & GPU-Compute
---Overclocking.Memory === true => Analytics & GPU-Compute
--RAM:
---Capacity === 32+ => Virtualization & Graphics-Programming
---Overclocking.Core === true => Performance & Cache Responsiveness
--Storage:
---Storage.OS:
----Capacity[Total] === 1+ TB & M.2 2280 => Multiple Applications[General Storage, Windows, Linux[Ubuntu, Arch, ...]]
---Storage.Extensive:
----Capacity[Total] === 8+ TB & SSD => Multiple Applications[General Storage, DataBase(s), OS Drive(s), Graphics]
---Storage.External:
----Capacity[Total] === 32+ TB & HDD => Multiple Applications[General Storage]
----StandAlone => true
----Form-Factor => less than (13", 13", 13") - M-ITX
--Cooling:
---Cooling.Coverage === (CPU & GPU & [Possible] Motherboard) => Performance & Bragging Rights
---Cooling.CPU-GPU.Type === (Liquid-Cooling, Custom) => Performance & Control
---Attributes.Liquid-Cooling:
----Cooling.Tubing.Type === true & (Custom, Nickel-Plated && Acrylic) => General Aesthetics
----Cooling.Coolant.Color === White && Yellow => Consistent White && Yellow Theme
----Cooling.Coolant.Effect === Opaque && Vue(esque) => General Aesthethics
---Cooling.CPU-GPU.Fan === true & (Flexible-Brand, Performance-Grade) => Performance
---Attributes.CPU-GPU.Fan:
----LED === true => General Aesthetics
----LED.Color === White(modded) && Yellow(modded) => Consistent White && Yellow Theme
----RPM === 2000+ => Performance & Noise-Cancellation Headphones
--Chassis:
---Custom-Workshop === true => Total Control & General Aesthetics & (Consistent White && Yellow Theme)
---Form-Factor === 25- L M-ITX && 8- L M-ITX=> New Obsession
---Attributes.Chassis:
----Material(s):
-----Panel(s) === Stainless Steel & (Tempered Glass && Acrylic) => Durability & General Aesthetics
-----Paint(s) === Urethane && Polyester Powder => Control & General Aesthetics
--Tweak(s):
---CPU:
----Delid === true => Performance & Liquid-Cooling Limitations
----Liquid-Metal === true => Performance & Lulz
---Storage.OS & Storage.Extensive:
----RAID === true => Performance & Sub-Profession-Specific Requirements
----RAID.Type === 0 && 1 && 10 => Performance & Extensive Requirements
-Software[Public]:
--Offline-App(s):
---SFF-Specialized CAD Kits => SFF-Chassis-Design Efficiency
----Q4 2018
---SFF-Specialized CAD Assembler => SFF-Chassis-Design Efficiency & Communication w/ Engineers & Workshops
----Undefined //not my project but a donation program from a friend
--Web-App(s):
---SFF Configurator => SFF-Configuration Efficiency
----Q2 2019
---SFF Configurator w/ Case Graphics => SFF-Chassis Visualization
----Undefined //can't promise much with my lackluster graphical skills
---SFF-Logs w/ Guides => Uniform Distribution of (Progress Logs & Accumulated Knowledge)
----Q3 2018
---Undefined
----Undefined //highly confidential SFF-Utility
[end]
TL;DR:
I'll be making custom and modded hardware, mainly cases, for private use and SFF-Utility software for public use.
Also I have this almost iconic Black/White/Yellow color-scheme, I'll be using custom paint-jobs to achieve aesthetic results.
Pleased to meet you all, getting ready to post my Shift (non-x) build with a 120 + 120 mm Radiator-Configuration this week, when the remaining parts arrive.
Then:
Modded Shift X => Custom-Workshop 22- L => Custom-Workshop 8- L => Who knows?
I use glsl/yml/json-esque pseudo-code syntax wherever applicable.
tinyitx
2,112
2,082
--Chassis:
[Computer animated voice]
Red alert!
A virus has been detected and highlighted.
''25 litre is not SFF'' - repeat this 3 times after me
25-L build should go to 'Offtopic'.
8-L build could go to 'Build Logs'.
[/Computer animated voice]
:D
Reactions: loader963
Cervine
Red alert!
:D
Not quite "Small Form Factor" but still a design based on the SHIFT X that's 8 cm shorter and has much less Contact-Area. The CAD Concepts will be provided, so we may get unbiased input.
