Since itx motherboard is 170 x 170 and Dan's height is 200, there is 30mm to work with for a radiator. My idea is to have a radiator with height of 25mm. Then with a customized chamber a 92 mm fan can be installed in the side panel. By doing this, cool air will be sucked into the case and exhausted out of the case. Also because the chamber is sealed, hot air won't warm up GPU. The other 92 mm will be underneath PSU just like 645LT.
