I bought a 2080ti yesterday and need a case now
eddiebalske
Hi guys,
Yesterday I bought a new GIGABYTE 2080ti Gaming OC ( 287x115x50) and need a new case now.
Can you please give me some advice :)
I would like to have:
- GPU must fit
- 240mm / 280mm Aio Support
- USB3 Type A in front
- max 15L
- sub 200$
My favourite at the moment is the Streacom DA2, but it's pretty big and doesn't has USB3
Thanks, Eddie
Instran0
526
107
Hi guys,
- GPU must fit
- max 15L
- sub 200$
Thanks, Eddie
what you're talking about is impossible.
you need to return your video card for a refund, and then buy this - https://www.zotac.com/us/product/graphics_card/zotac-gaming-geforce-rtx-2080-ti-blower
2,601
2,717
Ncase M1. 12.7l, graphic card support up to 317mm, 240mm AIO support, type A and C usb. It is just above your target price at $210. They will be up fro pre order later this month and ship in Sept.
eddiebalske
The Ncase M1 only supports GPU up to 45mm and I can't return the card. It was a bargain, brand new and only 900$.
heckinwoofer
101
142
The new revision of the M1 can fit up to 290mm, 3-slot GPU if you are willing to forego the front panel USB. Use a separate USB hub maybe.
The SM580 is also an option, just a bit larger than 15L.
There's also the Sidearm T1 and Dan C4-SFX but they are still in prototyping stage.
Reactions: eddiebalske
