CPU HP 6300 Pro SFF 6-pin power connector wiring
Apache23
Hello. I'm looking for anyone who has the SFF version of the HP Compaq 6300 Pro that is still using the original PSU. Been trying to find out the original wire placement on that P2 connector, so I can try to get it running with an aftermarket PSU. Thanks!
lozza_c
59
53
I've just rescued a 4300 from work so might be able to help if it's at all similar. I should have took a pic before I initially stripped everything out but if I recall correctly the P2 went out to daisy chain SATA power?
