Log How do I undervolt my i9-9900K on my ASRock Phantom Gaming ITX
MPKWGWBGATES1189888
A Very Good Day to You All,
I hope everyone is doing Very Well,
I have a i9-9900K in my ASRock Phantom Gaming ITX Motherboard
Both are sitting in my DansCase V4.1
I also have a RTX2080Ti Graphics Card in this setup
So far Everything is running smoothly without any glitches
I noticed that the CPU Temps are a little high
I would like to do some undervolting to maintain a low CPU Temp
May I please kindly ask how do I undervolt my i9-9900K on my ASRock Phantom Gaming ITX
Please kindly see the 2 attached Pictures of my Bios Parameters
May I please kindly ask - What Settings should I set for each of the below Parameters
Hope to hear from you soon
Thank you and kind regards Sir
tinyitx
2,279
2,338
Good guide to read to get a general idea to undervolting your CPU.
The guide uses Intel's XTU software but you can use BIOS if you like.
You need to find the 'CPU core voltage offset' (or equivalent) in your BIOS.
From the 1st pic, click into 'CPU Core/Cache Voltage' and see if it is there.
AlexTSG
599
590
www.youtube.com
The option you need to select from that menu is Offset mode.
CPUs adjust the voltage they use depending on the task they are performing. With the offset mode instead of setting a fixed voltage for the CPU to use at all times, you are setting the difference in voltage from the default.
To under volt you will set the offset to a negative value. You will need to test the setting for your particular CPU to make sure it is stable.
Start with a small reduction, then test using benchmarks such as CineBench and 3DMark. If the system is stable then reduce the voltage a bit more and test again.
