Discussion High quality smallish ATX cases?
Bourne3D
Hi!
I'm prepping my next build. It looks like the new Ryzen 7000 is going to have a peak around 230w and the RTX 4000 could be anywhere from 450-800w.
That leaves my SF750 out in the cold and 1000w+ PSUs are in.
I've had Ncase M1s, Sliger Cerberus X and other high end cases.
I really don't want to have to get a stamped mass produced case so I'm wondering if there is anything out there that is the same build quality as these high end SFF cases.
I don't want to mount the ATX PSU like you can in the Cerberus, if anyone would suggest that.
TLDR:
Are there any smallish ATX (PSU) cases out there that have high build quality.
Cheers!
hrh_ginsterbusch
139
54
wp-devil.com
If you do not care about "original intend use", then there also are
- NR200P - allows for an ATX PSU, and also mATX (there are several mods around)
- SSUPD Meshlicious - there is enough space for an ATX mainboard, and SFX-L
- Jonsbo VR3 - essentially a sub-20L (19.87) clone of the Meshlicious, which supports ATX PSUs up to 140 mm; should be, in theory, "take" ATX boards, too
- Streacom DA2 V2 - mITX / DTX, and SFX / SFX-L / ATX PSU
- Jonsbo V10 - mITX board, but ATX PSU form factor
- Raijintek Ophion Evo - same
Thats the ones with a good quality, at least that I know of.
Others that I can think of, but dont know about the build quality:
- Fractal Design Core 500
- Silverstone SUGO SG 14 / 15
cu, w0lf.
