So, I've been designing a case for a little less than a month. I did try designing a case before. I've gotten a little more experienced now. I'm going to remodel it in SolidWorks soon.
Details:
266.7MM GPU
Flex ATX PSU
Mini ITX Motherboard
Also, I decided to put a MX Compatible switch slot for the power button. It's the little square on the top right of the GPU I/O holes.
18 Gauge Steel
Dimensions (roughly): About 312MM x 277MM x 54MM
Size (roughly): About 4.66 Liters
I did have an older design, but it was a little bigger, so...
This is not meant to be a final design whatsoever. So, the size will fluctuate a little. Give me as much constructive criticism as you want. I'll try to use it and improve the design. Also, if you have any questions, I will try to answer any if possible.
Imgur Link:
Details:
266.7MM GPU
Flex ATX PSU
18 Gauge Steel
Imgur Link:
