Log Help! Dan A4 GPU Installation / GPU not working
jamflowman
Photos:
It’s all plugged in and everything else turns on - does anything jump out as incorrect in the photos?
Has to be something with the riser card - maybe it’s not in correctly? I pulled everything out of a previous build and all worked there.
Of note: the PCIe to MOBO connection does not “click” in like a GPU would, whether the lock is up or down I can still pull out the card
Not sure how to tell if the GPU is seated in the riser slot as there is no click or anything - really doesn’t look like anything for the GPU to click into.
Does that black cover come off?
Just bench tested without riser - gpu is working without riser.
