Hello from Denmark
Fruergaard
37
50
Thanks, this feels like the place to be for SFF inspiration and discussions :thumb:
(Perhaps I can start my case log now (includes links))
bledha
307
268
Welcome aboard! The case in your avatar looks really cool - can't wait to have a look at your build log!
Fruergaard
37
50
Can't seem to edit #0 with below:
It started out with Unobtainable, then a SG09 mod that got replaced soon after with my own case designs.
At the time there wasn't any real SFF cases so I looked into the option of using a laser cutter and assembly the parts into a good case (RAW V1 + V2) (Wood V1 + V2). This makes the cases cheap, easy to model, fast production and possible to create in various materials. Most of my designs can be downloaded and is free to use :thumb:
Raw V1 + V2:
Wood V1 + V2 (V1 never got of the ground):
If you want to build it your self, the 2D drawings is uploaded here:
https://www.dropbox.com/sh/gvfatib8gnjq06y/AAAVMfSu81-KovTgAdLkWuCMa?dl=0
BUT, note that:
1) The files are currently for 6mm material that can be clued together!
2) The PSU Fan cutout is specific for the AX850. If this is not the same on your PSU, the square in the bottom must be adjusted (size and positiong)
3) The PSU installations screws are placed only in the corners. Not all PSU's have that.
4) Check that the file has the right dimensions before you begin cutting. The small taps should be 15mm long and 6mm high
Reactions: Phuncz and Kmpkt
