Log Heatsink for IMB-180
G180
Hello everyone,
I own an ASRock IMB-180 motherboard that currently uses a fanless heatsink that covers both the CPU and the bridge chip.
I noticed that the CPU temperature goes above 80°C during gameplay,
so I'm thinking about replacing the fanless heatsink with 2 separate ones,
one with fan for the CPU,
and an aluminum one for the bridge.
The point is I cannot find the specs of the aluminum heatsink in the red square that you can see from the picture in the following link.
Picture of IMB-180
Do you know the model name or the size of this heatsink?
Thank you
tinyitx
2,112
2,082
Hello everyone,
Picture of IMB-180
Thank you
That bridge heatsink looks like a 'standard' heatsink to me.
Instead of finding the spec, I suggest taking a more direct and practical approach. That is, just measure the distance between the 2 mounting screws/holes. Then, you can look for 'standard northbridge heatsink' with matching mounting holes.
Example
38x38x30 https://www.aliexpress.com/item/32538630458.html
