I'll re-use these components from current build:
The dimensions should fit L=280.35 W=116.45 H=40.24 mm.
Do you think it's a good card for the Louqe Ghost case?
Do you think the temperatures will be a problem? I would rather not use a top hat.
- i5-8400
- HyperX Fury DDR4 2666MHz 2x8 GB
- 1 TB M.2 SSD
- 4K monitor
- ASUS ROG Strix B360-I Gaming, S-1151
- Noctua NH-L12S
- Corsair SF600 SFX Platinum
