Geek A60 AIO susggestions
chika7ilo
Hi guys, i have registered to the forum because i am building my first itx build and i need some advice.
I ordered the Geek A60 case and i was wondering what AIO should i buy?
I was looking at Deepcool Castle 240 RGB V2, but i saw that the tubes are a little bit shorter then other AIO.
Will the tubes be a problem?
Thanks.
2,413
2,489
Thanks.
Short tubes are a plus for itx cases. Most AIOs are designed for mid tower cases with a fair distance to mounting location and you have to deal with all the excess tubing. The Deepcool has 310mm tubing length which is way more than you are actually going to need.
Reactions: chika7ilo
chika7ilo
Well this was quick, thanks for the quick answer.
So the short tubes are a plus, great then. Any suggestion on another AIO?
