Log G-unique DiY stuffs \\ROME wasn‘t built in 1 Day,but can be built in 3Litres:A 3L 64C RTX3070 ROME-ITX watercooled internal PSU PPL beast\
guryhwa
G-Unique
Dec 23, 2016
164
961
it is a fully custom (cooling +case+psu +flex pcie cable parts )build log,
to get ppl score as high as possible in as small as possible case:
estimates size is 21.8cm L * 19cm W * 6.5cm H,about 2.7L
hardware :
Asrock rack ROMED4i-2L
AMD EPYC 7742QS 64C128T
16G*4 DDR4 3200 RECC
980PRO 512G
RTX3070FE
guryhwa
G-Unique
Dec 23, 2016
164
961
custom hybrid cooling system(watercool+heatpipe+vaporchamber):
1,Vapor chamber coldplate for SP3 EPYC cpu socket:
2,5*6mm heatpipes block and mounting mid-frame for RTX3070,all of the GPU's heat is thermal coupled to the CPU VC coldplate:
3,0.2mm pitch micro channel water block soldered to the CPU VC coldplate,take the heat away:
4,reflow soldering part 1-3 together:
testing/eval the cooling ability of the Custom Combo Cooler(CCC)with a 120 alu rad(144cm^2 fins area equal to 90mm*160mm custom rad):
default clock CB23 is about 54K
after a light OC to 3.2Ghz CB23 raise to:
5,use epoxy resin to build a tiny 2nd 10cc RES upon the coldplate of VRM components,and the inlet copper tube is soldered to the VRM coldplate to absorb VRM.s heat:
6,custom made rad: ultra thin 18cm*1.4cm 3 rows 480 pieces cooper fins ,and aditional U-shape rad.cooled by dual 92mm*12mm PWM 12v0.25A fans:
Boil
1,252
1,094
hardware :
980PRO 512G
RTX3070FE
Dude...
Cheese & rice...! ;^p
256
No sign of Gury anywhere since July, so hopefully he’s ok and we’ll get an update eventually.
