FlexGURU PRO
www.fsplifestyle.com
Looks like they finally released the 500w model! Finally a high-wattage black flex atx psu. I wonder how the acoustics are though.
My only question is does it use the same fan as the fx350g? Because if it does that's gonna be a bummer. The page is a bit vague about the fan - it calls it quiet and "silent", but also states it as 20dBa minimum, so not sure what to go with...
This is on the product page:if it is 20dB minimum and 35dB maximum that is not too bad but also not great. also depends on the frequency if its annoying or acceptable. Personally I prefer the fan to be exhaust but placed inside, like the FSP and HuntKey. This lowers the noise quite a bit.
seeing that the fan is load controlled I just hope noise is acceptable for <=300W output without a fan swap
PS: did you see the length of these cables?
Yes, we have been buying these power supplies for a long time. They are very quiet and really powerful. The 300-watt model fully supports the RTX2070 without overshooting and understating the limit.Oh lord I just found out about this, that is so cool! It seems to not be in stock currently, has anyone bought this?
They also got two modular FlexATX PSUs the FlexGuru 250W and 300W now, which is awesome! Really clever that they put the control signals on a smaller connector, that saves just enough room to get it into 150mm.
We bought one from Amazon and tested it. This is an incredibly cool Power Supply. I am overwhelmed by its quiet operation up to 350 watts!FlexGURU PRO
