Production FormD-T1 (Sidearmd), CNC + AIO + 9.5L
Brand name will be "FormD", help us pick a website address:
  • Total voters
    397
Jayanth
47
notbitcoin is saying the stuff they've ordered is unprinted. I'm making a new order at work, so we'll see if they're still doing it. Yesterday I looked at the stuff we currently have deployed, and the markings can be scraped off for the most part. So either way, it's not a big deal.
Yes, I've found that printing on the EPDM from McMaster Carr comes off with IPA pretty easily.
Wahaha360
Overhaul
1,257
4,527
You meant to say, "he didn't mean for this to be a full time job, but it has become more than a full time job on top of his current career", right?
When asked what I do for living, my response “scrap metal artist”, that’s how you get the ladies you know 🤣
When asked about hobbies, my response “empty metal boxes”, that line is conversation starter at wedding parties 😂
Roen
44
Hi, do you think a 59.9mm GPU like the AORUS RTX 2060 Super would fit in here? Or is that too much of a stretch?
I believe each slot = 20 mm of thickness and there is a 3 slot config.
As for 59.2 vs 59.9, I would imagine there's enough play for 0.7mm of clearance, but I'm just speculating.
prava
155
219
Yeah well, I'm sure if you take some of the CNC pieces, put then on a pose and give them some photoshop they might qualify as sculptures (so long as you don't make their size obvious) 🤣🤣🤣
Wahaha360
Overhaul
1,257
4,527
any updates on morpheus?
bigben, hetvler, Boil, madejackson
Met with SirJack this today, the Morpheus II + Noctua 15mm Slim fans will not fit in 3-Slot GPU Mode. Maybe 5mm too thick.
Which makes me believe the Accelero Xtreme III should fit.
Nvidia RTX 3000 series is coming anyways, so maybe a full 3-Slot air cooled GPU will be the better way to go.
pwnedundies
83
135
I agree in the stock config the Accelero Xtreme III is 54mm (with fans and shroud) not including the PCB/backplate of the card.
In the tomshardware review it adds 6mm. So take the default fans off for slim ones and it will most likely fit
fabio
1,035
1,700
Alphacool has this 10/13mm ittings if anyone is interested! I will use them in the future 3900X/Titan V full watercooled system!
Reactions: PBJ
panzermuffin
74
103
Neat. This one is 7mm narrower than the EK one (21mm vs. 28mm): https://www.ekwb.com/shop/ek-af-angled-90-g1-4-black
Proflucifer
74
27
Just curious. How much worse are the temps of a sidearmd t1 with a glass pannel co pared to one with a mesh panel?
hiepphotog
26
Been going back and forth between this and a few other potential cases here, but I think my heart finally settled with this one. Good airflow, great size and nice looking. Can't wait till I can order this. I'm currently using the Cerberus for my threadripper rig, which is about twice the size of this case.
PBJ
282
376
Actually got a couple of those fittings in the mail Yesterday.
SSJ4
77
84
www.ospreygaming.com.au
@ Australians who are planning on getting an LT240.
Having trouble tracking one down for a reasonable price. Cheapest I've found is direct from Alphacool but it will be over $220AUD.
Another option is to build my own because I can track down a Fractal Kelvin and swap out the rad. But I would need to use a different radiator than the LT240. Which I do not want todo. Rather stick with the OP's recommendation.
HMU in my DMs or here if you have found a good way to get them.
gwertheim
445
534
I just looked into mailing you one it would be roughly the same price as if you got it in aus plus shipping
Reactions: SSJ4
