Log Form-d Partslist compatible?
Furybadger
PCPartPicker Part List
CPU: AMD Ryzen 3 3300X 3.8 GHz Quad-Core Processor (£119.99 @ Amazon UK)
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler (£77.99 @ AWD-IT)
Thermal Compound: Thermal Grizzly Conductonaut 1 g Thermal Paste (£8.19 @ Amazon UK)
Motherboard: Gigabyte B550I AORUS PRO AX Mini ITX AM4 Motherboard (£179.99 @ CCL Computers)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (£135.46 @ Scan.co.uk)
Storage: Seagate FireCuda 520 500 GB M.2-2280 NVME Solid State Drive (£107.99 @ CCL Computers)
Storage: ADATA Swordfish 1 TB M.2-2280 NVME Solid State Drive (£123.65 @ Amazon UK)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card (£369.99 @ Ebuyer)
Power Supply: SeaSonic FOCUS SGX 500 W 80+ Gold Certified Fully Modular SFX Power Supply (£105.46 @ Scan.co.uk)
Case Fan: ARCTIC 72.8 CFM 140 mm Fan (£9.69 @ Overclockers.co.uk)
Case Fan: ARCTIC 56.3 CFM 120 mm Fan (£12.50 @ Amazon UK)
Keyboard: Redragon K552 Wired Gaming Keyboard (£69.98 @ Amazon UK)
Mouse: Logitech MX Vertical Wireless Optical Mouse
Custom: Form-d T1 sfx / mini itx. (Purchased For £210.00)
Total: £1530.88
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2020-09-07 17:46 BST+0100
Bought the case, been planning this build for a while.
Leaving options open for future upgrades... planning on making custom cables, possible custom loop.
Used for 1440p gaming. Mainly RTS/survival/Sim builds, occational fps.
Can you help with my thoughts/questions:
CPU - will upgrade in future. budget towards gpu for now. bottleneck seems to only be -5% when using 3300x with 5700xt
AIO - which will fit in the T1?
GPU - I will wait for 3070...
MB - ??
DDR4 - low profile
Storage - high performance for boot, then larger for library. Does the case fit 2.5"/3.5"? whats a resonable option for high capcity storage?
PSU - ??
2,704
2,834
I can't really comment on the other parts but you want a different PSU. The Seasonic is not a SFX but a SFX-L and will be too big.
Reactions: Furybadger
devolv
54
38
140mm Artic Case fan would be too big for this case. 120mm is the largest diameter you can run. The thickest is 25mm on the PSU sude, 15mm above the motherboard.
Furybadger
Thanks for info, Fans were just in there as placeholders so I don't forget. I was tickled by someone who velcro'd a larger fan above their cpu block as extra 'vrm' cooling solution in the T1.
So with that AIO I can only fit 1x 15mm fan. The rad is 38mm thick. Any AIO recommendations for this case? or go air cooler until I do custom loop?
thelaughingman
1,413
1,566
MB - ??
DDR4 - low profile
PSU - ??
First on your current part list, the Gigabyte card is ~50mm thick which requires the T1 in 3 slot mode, which then makes the Liquid Freezer incompatible - block too tall, plus hoses coming out on top. I doubt it would even fit in 2 slot mode.
Second on your questions:
  • CPU: just wait for the R5 4000
  • AIO: EK 120/240 D-RGB, Corsair H100 XT, Alphacool LT240
  • MB: I think you're already set with the Gigabyte B550i, it's a really great board for the price
  • DDR4 - not sure about smaller brands, but only Corsair LPX is 33mm or lower since Crucial stopped making Ballistix Sport LT. Though you could still get the new design Ballistix (MAX), it's only 40mm and RGB if you want it
  • Storage: T1 fits 2.5", no 3.5". my build is dual M.2 so I don't need any SSD/HDD
  • PSU: Corsair SF600/750, FSP Dagger 600/650, Silverstone SFX 600/700 (upcoming)
Hope that helps!
Furybadger
Hope that helps!
Thats really great info, Thanks.
Reactions: thelaughingman
