Power Supply Flex Psu 500w+ need help
cosmopock
i'm confiused whitch power supply to buy . I brought recently metalfish s3 and k39 case and i really need advice what psu to buy pls help im a newbie in this subject . Do you know any good psu available on aliexpress or ebay i live i europe ?
prayogahs
208
272
Recommend the Enhance ENP-7660B 600W Platinum as it has a quiet fan. It is available to purchase below
EDIT: Also in velkase's website:
cosmopock
thanks fo the reply but is it original i heard that this PSU is out of stock on original seller website ?
prayogahs
208
272
They are all should be genuine Enhance PSUs. I did buy one from the taobao store. Enhance does not sell PSUs directly to consumers so all the ones I listed are all resellers. There is no so called "original seller"
cwspellowe
Servercase on eBay have some new ones with warranty for fair prices, I just ordered one and paid £160 Inc shipping and customs fees to the UK. I'd recommend staying away from anything Delta as they tend to be refurbished and poor quality, the 7660b seems to be highly rated.
lephoul
Hello,
I can see that FSP500-50FSPT has END OF LIFE status and REPLACED WITH:FSP500-50FDB,
The only difference I can see is the fan location, in 50FDB it is placed at the back,
Does any one has any experience with 50FDB ?
kzoltan
Hello,
I have it ordered from overtek. I have replaced the fan to noctua 40mm, works fine with ok noise this way.
Reactions: lephoul
