Log First Build - NCASE M1 v6.1 + 5950X + TRINITY 3090 OC
FredT
Hello,
After a lot of reading and hesitation, this will be my first build ever
Parts​
Model​
CASENcase M1 v6.1 Silver
CASE FanNoctua NF-A9x14 PWM Chromax
PSUCorsair SF750
MOBOAsus ROG Strix B550-I
CPUAMD Ryzen 9 5950x
CPU CoolerNZXT Kraken x53
CPU FansNoctua NF-A12x25 PWM (x2)
GPUZotac RTX-3090 Trinity OC deshroud
GPU FansNoctua NF-A12x25 PWM (x2)
RAMCrucial Ballistix DDR4-3600 C16 2x16GB
SSDSabrent Rocket 2TB
The case is still at the customs and I'm waiting for the delivery of the CPU and the GPU...
Let's see how long it will take
Edit 26/03 :
Ncase received
Initially ordered a TUF 3080 OC with a price guaranteed until 30/04 but not even sure I'll get one before September apparently...
They offered me a Zotac 3090 Trinity OC from an "unhappy" customer so I went for it
Still in line for the CPU (5900x and 5950x) which should arrive mid-April
Edit 06/04 :
Missed the delivery for AMD restock at my store, I'm now 11th position for 5950x and 160th for 5900x
Better chance to get my hand 5950x first but not before June apparently ...
I might take a 5800x in the meantime
Edit 12/04 :
Received the tray version of the 5950x, I'm ready for action 🥳
Edit 12/04 bis :
Apparently a mistake, a box version just left the store, I have to send back the tray one
I should assemble everything by the end of the week
Edit 13/04 :
Boxed version received, tray one sent back
FredT
Cable management nightmare !
Final result
Didn't mount the Noctua A9 as I notice, while building, it was not the 14mm version 😩
Thermals are ok, 60°C while playing 1440p
Will see when 4K TV will arrive but I'm afraid of the VRAM as I noticed it was reaching high temps while benchmarking the card
It's on the back of the card, and even with the A9 on the rear, it's not helping
I might water-cool it...
Reactions: thelaughingman
124C41
Hey Fred,
I've read from other configs with the 5950 that some people have had to set the PPT in the bios to 120 down from the 140 default. Have you had to under clock the cpu on this? Is that 60 degree C reading you're getting at standard 140 PPT?
FredT
Hi 124C41
Sorry for the late (late) reply
To be honest I didn't touch anything on the CPU nor GPU
I've put the Asus Auto Performance in the BIOS which set the frequency of the CPU to 4GHZ... Always...
And for the power, I don't even know...
I'll check once my setup will be up and running again
FredT
So....
After receiving the LG 55C1 and played some Ultra 4K games, I've noticed the VRAM was around 90°C as an average and it was a bit noisy
I decided to watercool the GPU as well, which means, custom loop
Waterblock
CPU : EK-Quantum Velocity D-RGB - AMD Nickel + Plexi
GPU Front : EK-Quantum Vector Trinity RTX 3080/3090 D-RGB - Nickel + Acetal
GPU Back : EK-Quantum Vector Trinity RTX 3080/3090 Active Backplate - Acetal
Reservoir : Iceman NCASE
Pump : EK-DDC 3.2 PWM (12V PWM pump) + EK-DDC Heatsink Housing - Black
Rads
Side : EK-CoolStream PE 240
Bottom : XSPC TX240
Fittings
EK-Quantum Torque STC-10/16 - Black (x10)
EK-AF Classic Angled 90° - Black (x4)
EK-Quantum Torque Rotary 90° - Black (x3)
EK-Quantum Torque Rotary 45° - Black (x1)
Koolance QD3 Female Quick Disconnect No-Spill Coupling - 10x16mm (x2)
Koolance QD3 Male Quick Disconnect No-Spill Coupling - 10x16mm (x2)
Koolance Swiveling Elbow G1/4 Low profile - Black (x1)
Tube : EK-Tube ZMT Matte Black 15,9/9,5mm
Misc :
Alphacool Eiszapfen temperature sensor G1/4 IG/IG mit AG Adapter
EK-Leak Tester
EK-ATX Bridging Plug
EK-CryoFuel Clear (Premix 1000mL)
Distilled water
Temperatures to come
