With Pre-order now open and production looming at the start of 2025 we're pleased to announce finally we have all the bells and whistles on one Flex ATX PSU straight out of production. Yes, Enhance Electronics after years of pushing have finally taken the superb ENP-7660B (aka FX600) and given it what's been waiting for for so long. The full modular treatment. No 3rd party flying leads and external uncertified PCB mods, but a single solid PCB with full modular connectivity coming in at 165mm long. Still short enough to fit any Densium 4, Velka 3, and many more SFF cases out there.
ENP-7660L-OVT carries over the core component and circuit design from ENP-7660B and has been enhanced and updated to comply with PCI-E 5.0 plus with an extensive silicone loom set ENP-7660L-OVT caters for many of the most popular case design layouts. This includes x2 24pin ATX cables 18/35cm respectively. x2 CPU cables 40cm.One single solid 8pin CPU connector and one dual 8pin + 4+4pin CPU for dual 8pin CPU motherboards along with legacy. x2 GPU cables 25cm. One 12V-2x6, 450W designated, back compatible with 12VHPWR and one dual 6+2pin PCI-E cable. Covering the great majority of GPU power requirements for SFF systems and servers. X1 peripheral cable with 2 SATA connectors
Furthermore a unique feature for ENP-7660L-OVT is the capacity to Daisy chain PS-ON for remote ON/OFF control. Either from a master PSU or from a switch. Optional and customisable cable(s) will made available later for this function to suit particular requirements/applications.
ENP-7660L-OVT is ATX3.0 compliant, as this retains a longer hold up time than the ATX3.1 specifications. This is a conscious decision held in place as it's more critical for systems used with UPS. Which can be either for servers or locations with bad power conditions. Having the longer hold time allows maximum headroom where systems are supported UPS, in particular for the lower cost type of standby / offline UPS where switch over times are in some cases than the shorter hold up time defined by the ATX3.1 standard. Hold up time is the time a power supply can maintain its regulated voltage output during a power outage.
ATX3.0 and PCI-E 5.0 in effect the best of both worlds. Longer hold up time and better power connector.
ENP-7660L-OVT link for info and ordering
