Cooling EKWB - Rotary Terminals for the Full Cover Blocks
LocoMoto
DEVOURER OF BAKED POTATOES
287
335
So, THIS, the Rotary Terminals from EKWB is something I personally find very exciting as it enables more widespread and in general just more uses of single slot cards that are liquid cooled in SFF enclosures!
It features PTFE-coated forged brass with G1/4" threads for the ports and is compatible with their FC (Full Cover) Blocks, although not compatible with their CSQ design full cover blocks.
Do any of you have thoughts on this?
Is it something you have a use for? What would you change? What alternatives would you consider?
Please share your discussions with all of us!
LocoMoto
287
335
Indeed, these things have pretty much sold me on the EK offerings of blocks for the custom loop in a Node 202, would otherwise have had to expend even more than that on a cheaper block + custom terminal fittings! as their angled terminals are just a tad too large for comfort.. Might be a joke in there somewhere.
