Press Release: When an article is marked as such, it is posted verbatim from a Manufacturer’s text, and does not reflect the views or opinions of SFF.Network.
EK®, the premium water cooling gear manufacturer, is expanding the Quantum Torque line of fittings by introducing double rotary offset 21 and 28mm adapter fittings. The EK-Quantum Torque Double Rotary Offsets are premium-quality male-female interconnects with G1/4″ ports offsetted by 21 or 28mm. The fittings come in two offset sizes – 21 and 28mm, and can rotate around two axes due to two revolvable joints. They can be used to offset two parallel or perpendicular tubes and are best used on GPU and CPU water blocks to align the tube directly with the distribution plate port. Aesthetically, they perfectly match the fittings and adapters from the EK-Quantum Torque series.
EK-Quantum Torque Double Rotary Offsets 21 and 28
This double rotary offset series consists of 8 different models with varying finishes and offset sizes. They...
Continue reading...
