NOTE: This is a press release. It presented exactly as the company released it with no editing by SFF.N. In this instance, EKWB’ s wording is unchanged and presented as EKWB wrote it. The photos and videos are in the same place they were in the EKWB Press Release where possible. All photo credit is EKWB’s. While we at SFF.N try avoid using direct press releases for our news coverage, there are instances when doing so is necessary due to time constraints.
EK, the leading computer cooling solutions provider, is expanding its soft tubing portfolio with a new tubing option from the EK Pro line. The latest product, EK-Pro Tubing 10/17 mm Reinforced EPDM Preformed 45°/90° – Black, as the name suggests, is a water-cooling tube made of reinforced EPDM (ethylene propylene diene monomer) rubber. While EPDM tubing is generally soft, this solution is reinforced with nylon to form a semi-hard tube with one 45 and one 90-degree angle. It is excellent for locations that aren’t easily accessible...
Continue reading...
