Dynatron earlier this week rolled out the L15, an all-in-one, closed-loop, liquid CPU cooler. This cooler features a radiator-mounted pump, so the CPU water-block is considerably slimmer for a cooler that's capable of handling thermal loads of up to 250 W. The 240 mm x 120 mm radiator comes with a pair of 120 mm dual ball-bearing PWM fans that can turn at speeds ranging between 600 to 2,400 RPM, pushing 23 to 92 CFM of air-flow, with noise output ranging between 16 to 38 dBA. The cooler supports the latest Intel LGA1200 and LGA115x sockets, and AMD AM3+ (or older) sockets, although the company does not mention AM4 support in its data-sheet. The company didn't reveal pricing.
www.techpowerup.com
![](/forum/proxy.php?image=https%3A%2F%2Ftpucdn.com%2Fimg%2F4jWwhico2EIQN9ae_thm.jpg&hash=78ad06a299be843485fdb2ee8c1692a8)
![](/forum/proxy.php?image=https%3A%2F%2Ftpucdn.com%2Fimg%2FY06qeyGvom8wn6vz_thm.jpg&hash=369df14bdd622f407df57dcf30f15952)
![](/forum/proxy.php?image=https%3A%2F%2Ftpucdn.com%2Fimg%2FF0kYsM5uKDZIuQsi_thm.jpg&hash=ae7886a238ac14da38ce0a62830a71c6)
![www.techpowerup.com](/forum/proxy.php?image=https%3A%2F%2Fwww.techpowerup.com%2Fimg%2F4jWwhico2EIQN9ae.jpg&hash=f9622a97a230caa5d846b94811752562&return_error=1)
Dynatron Rolls Out L15 AIO Liquid CPU Cooler
Dynatron earlier this week rolled out the L15, an all-in-one, closed-loop, liquid CPU cooler. This cooler features a radiator-mounted pump, so the CPU water-block is considerably slimmer for a cooler that's capable of handling thermal loads of up to 250 W. The 240 mm x 120 mm radiator comes with...
