First, sorry for my bad english but bare with me. Im doing a custom itx build and i have problems fitting sfx sized psu into the case. So would i be able to run the setup with two 160w pico psus?
components would be pentium g3258 overclocked to 4G and gtx 750 ti sc. Total power consumption would be somewhere around 200 watts so the to picos should be enough.
but the problem is that the gpu doest have extra power connectors so it draws all its power from motherboard so i just cannot connect one pico to mother board and another to the gpu. Could i solve this by connecting one pico to the 24pin connector on the motherboard, then jumping the another pico and connecting it to 4pin/8pin cpu connector?
I found 500 watt picopsu from aliexpress but it needs 330 watt dell power brick which is very expensive, far more expensive than two 160 watt power bricks. Am i able to connect two power bricks together to create a 320 watt power brick?
