Closed DSX1 Prototypes - DeskMini Series X Console Style Case DIY Set
I made a few samples of my DSX1 XBOX Style Case and some people asked me if they could buy one of those.
The samples have some flaws, e.g. the powder coating is not absolutely smoooth, but are still good to use. I am selling them as set with PSU and riser cable.
The DSX1 Set includes:
  • DSX1 Case (black powder coated Aluminum)
  • MEANWELL RPS-400-12-C Power Supply
  • GxR Load Switch Module
  • ADT R43-ML M.2 to PCIe Riser Cable
  • USB 2.0 Pigtail Cable
  • Audio Pigtail Cable
What you still need:
  • AsRock DeskMini A300 or X300 Barebone
  • APU, RAM, SSD, WiFi
  • CPU Cooler with max. 50mm height
  • Case Fan: 140 x 25mm
  • Graphics Card:
  • IEC C5 Power Cord
Asking for: EUR 135,- plus shipping
You can order from me directly via PM or
from my shop
Any questions, just let me know.
celestialz
sorry, 1 question, can the power supply a Zotac 2060 OC 6GB GPU? as the size can fit into DSX1
REVOCCASES
REVOCCASES
2,166
3,504
www.revoccases.com
is it this one?
Should be a good fit...
power supply is sufficient, I currently have a RTX2070 in there.
due to the height of that card you may or may not need one of those adapters, but I can include one for free should you like to get a DSX1.
REVOCCASES
REVOCCASES
2,166
3,504
www.revoccases.com
I have updated GPU size compatibility. Seems with 125mm height you have to squeeze the PCIe power cables a bit too much.
max. GPU height with angled power adapter: 130mm
max. GPU height without adapter: 120mm
For the samples I will include a set of those adapters FOC if needed.
