Is there a practical or performance difference between the M.2 NVME connectors on the ASRock A300 STX motherboard in the DeskMini?
I will put in one NVME drive, and will probably put it on the back of the motherboard to allow easier access in the future should I want to add a second SSD, since I don't have to remove the motherboard for the second SSD. I would use the front connector if there is a performance advantage to doing so.
Is there an architectural or performance difference between the two connectors, that would make me favor the front connector?
