Stalled [New Video Assembly] Densium 4 & 4+ - Tiny cases with real hardwood frontpanel!
Overtek
OVERTEK
308
497
www.overtek.co.uk
You can, with the power supply off, just snip the sata-cables and put a shrink tube cap on each of the sata-cable ends. Less cables to worry about :-)
Yes, Or desolder the part of the loom you don't want for a clean finish.
Happily provide stripped down loom this way at no extra cost on 600W Enhance ENP-7660B. 3yr warranty would remain.
If shortened ATX 24pin / CPU / PCI-E looms are needed as well that would be an additional cost due to time in unpinning, cutting, stripping and recrimping.
Either way we've over 10 years experiance doing this on over 3,000 Flex ATX PSU's.
Reactions: Densium.net
Bakaban
120
110
Love the idea, but honestly, if it is cheaper than the velka 3, I'll take your entire stock. I love the idea of the wooden front panel. Maybe you could make it so that you could design a custom front panel and swap it out(such as let's say I want to CNC one which offers more airflow for the case)
So, taking the entire stock then are you? My order is already in. Cooler plus case at this price, it's like a Norwegian Santa Claus is sharing the christmas spirit! :-)
Neathdrawls
260
480
Looking forward to seeing it in the hands of people soon, as it ramps up to production with my order in as well!
Edit: Anyways, just to confirm, GPU length compatibility is now at 180mm long? As it’s still stated as 175mm in the first post.
Densium.net
191
309
Hey man, thanks for your order!
Yes the lenght inside the case is 181mm +/- tolerances!
Revenant
Revenant Tech
1,674
2,708
I ordered one as well. Neat design, and I always wanted a wood front case.
Densium.net
191
309
I ordered the white with rosewood. I found this power supply that I would like to use with J-Hack's M2426 to lessen the cable clutter.
Has anyone done business with this Taiwanese company?
Enhance Custom Flex ATX Modular PSU L-Type (90 degrees) – GEEEK CASE (geeekstore.com)
Geeek is a highly regarded company. But unfortunately their modular PSU’s will not fit in the Densium 4, due to the added lenght. If you need the modularity, you should opt for a FSP Flexguru 500W!
Bakaban
120
110
There's a thread in the hardware section of a guy that built a k39 with a geeeek modular flex psu. Unfortunatly, it seems like they did not take as much care as you'd expect with the extra cables they needed to remove to make it modular. Overtek stated they desolder the extra wires in their custom enhance psu solutions, which is the way to go. It seems geeeek just snips the unused cables off inside the housing and leaves them like that, copper exposed. (https://smallformfactor.net/forum/threads/build-review-k39-geeek-600w-modular-psu-enp-7660b.12384/)
Aguda33
107
187
Thank you for your quick response. The model I linked shows a depth of 170mm, that includes the ATX connector. The Flex Guru is shorter, but I want to eliminate all the unneeded wiring. My desire is to reduce the 30 wires down to 6 wires with the M2426. I have 2 computers that have been running flawlessly on the M2426.
J-HACK M2426 - Hybrid DC-ATX 24 Pin Adapter (j-hackcompany.com)
My alternative is to use a custom modified supply by Overtek at 150mm. I am uncertain of the wiring length needed, but can make a reasonable guess.
600W Flex ATX 1U Platinum power supply Enhance ENP-7660B – Overtek
Merry Christmas and Happy New Year to all !
Aguda33
107
187
Thank you for the heads up ! I guess I shall steer clear of this one.
Densium.net
191
309
Just realized i meant the 300w flexguru. 300w could be enough, depending on your hardware.
vlad1966
57
31
I ordered a couple of days ago. I ordered the walnut with satin white. I think it should make for a nice contrast. A couple of weird questions :
- Is the wood front "real wood" or "engineered wood"? Not that it matters much as I'm sure it will look great. Just curious.
- If "real wood" will the pattern of the grain look different than what shown on the Densium website? That looks nice.
Thanks - looking forward to receiving the case & thanks for the great deal.
Also, I ordered the PCIe Riser. Assuming it's only x3 speed & not x4?
Densium.net
191
309
Hello,
Yes, it is indeed real wood! Yes, the grain will be different for all units! We did not cherry-pick the grain for our prototype, so it’s representative of what you’re getting :)
Our current risers are Gen3, but we’ll get ahold of some Gen4 in the future.
Have a nice day!
Audun
Aguda33
107
187
Check out the December 25th update on the thread guys, good news!
Hello Audun,
That is indeed great news ! I am looking forward to building in this beautiful case. Time for me to gather all the needed components. Do you have any recommendations for wiring lengths ? The wires that come with the power supplies can take up a lot of space blocking airflow. Thank you!
Hugo
Reactions: Overtek
