The idea is to use LiPo battery as power source like laptop (an ITX one). So it must use AC adapter as charger.
I readed Battery Powered PC and come with idea to use 5S BMS (18,5V-21V) with serial connection (UART) monitoring, but it hard to find this kind of BMS (i found 7S BMS) or is expensive. And need boost circuit for charging.
There is OpenUPS with balancing, monitoring and charging, but it is only 6A input/output.
Then i found combo device for charging/balancing and some monitoring: ISDT SC-608 (or Q6 Lite). Other problem is how to shut down PC properly when battery is low. So i found M4-ATX, but is 12A on 12V rail (not sure if is powerful enough). Anyone experience with this one?
All ideas and suggestions are welcome. If you have experience with this topic, i will be glad to read your opinion.
Diagramm how i think to use DC-DC with battery:
