hi.
in Korea, there is company that makes a custom case called MEG.
and MEG has released a DAN A4-style case, which can also be purchased as a custom order.
I wanted to use two 120-mm radiators on this small case, so I made a custom order with the drawing(blueprint?) using paint.
and they confirm my order.
anyway, this is my build.
I built this system by placing two 120mm radiators(CPU, GPU) on the case.
size is 138(W) x 320(D) x 212(H)mm (with radiator, height is 265mm)
CPU : 4790k
M/B : ASUS- Z97i itx
SSD : micron Crucial mx300 M.2
VGA: MSI 1070 SeahawkX
PW : Silverstone SFX SST-600-G
front radiator was Graphic card radiator. (MSI 1070 seahawk)
there was no hole in the side of the case, so I had to penetrate the radiator to the top of the case,
(failure)
(succes)
like this.
rear radiator was CPU radiator.
I order make a hole in the top of the back panel to make the pipe(hose?) pass
like this. (right side is power and power button extend line)
Finishing VGA side.
setup main board and power.
I installed M.2 to use no SATA power and data cables.
and finally close the pannel.
The side panels were designed with air circulation in mind,
on the VGAside panel, there is a long hole for air intake,
On the main board side, I made an air intake hole at the bottom.
for incoming air passed through the main board to cool mainboard.
this is the temperature after Fire strike test + overwatch 30 min play.
kind temperature. good.
SFF with high performance is always good. haha.
This is my first post,
and there may be some things you do not understand because of my lack of English.
Thank you for watching.(reading)
and really Thanks for Google translate.
CPU : 4790k
(failure)
(succes)
like this.
Finishing VGA side.
