Enclosure DAN A4 - version differences
Doffen
Hello!
I´ve ordered the DAN A4 v4.1 case, but due to delays and low availability I´ve started looking elsewhere
to purchase a used case and while searching online I found a v2 case.
I was wondering if anyone here knew what the differences between the different versions on the DAN A4 SFX were,
beyond the USB A / USB C front port and the included Gen3 / Gen4 PCI-E riser cable,
and if they have any impact in regards to building in the case?
Thanks in advance! :)
Shaytanya
38
Hey there - see below and how it might affect your built - the main difference between 2 and 4.1 are the 120mm AIO (as opposed to the 92 AIO for v2) compatibility and the ability to install a 92mm (recommend Noctua) under the MOBO for additional cooling
  • 3M™ 8KC3-0726-0300 PCIe® x16 Gen4 riser
  • USB 3.2 gen2 Type-C front port with internal Key-A
  • ADT R33UF-TU PCIe® x16 Gen3 riser
  • USB 3.2 gen1 Type-C front port
  • 92mm fan mount point under the motherboard
  • Pre-drilled threads for custom window kits
  • The 120mm AIO bracket is now optional
  • Lian Li PCIe® x16 Gen3 riser (black PCB and cabes)
  • Adjustments to the USB3.0 internal cable to be compatible with Asetek® 92mm AIO
  • Improvements to the power button to optimise the pressure point
  • Adding mount points for HDPLEX 400W HiFi DC-ATX
  • Mounting bracket for 120mm AIO
  • Cover for GPU mount area
  • Better alignment of USB port
  • Stamp-in motherboard stand-offs
  • 92mm fan or AIO mount point
  • Rubber case feet with better grip
  • Kensington Lock
Doffen
Thank you! Only thing that matters for me it seems would be the lack of a fan mount under the motherboard.
Reactions: Shaytanya
