my 2nd compilation after evaluation from the net.
Preisvergleich und Bewertungen für Pc Zusammenstellung
geizhals.at
1 Silicone Power P34A80 1TB, M.2 (SP001TBP34A80M28)
1 AMD Ryzen 7 3700X, 8C/16T, 3.60-4.40GHz, boxed (100-100000071BOX)
1 Crucial Ballistix black DIMM Kit 32GB, DDR4-3200, CL16-18-18-36 (BL2K16G32C16U4B)
2 MSI MPG B550I Gaming Edge WIFI (7C92-002R)
1 Noctua NF-A9x14 PWM, 92mm
1 Noctua NF-A9 PWM, 92mm
1 Noctua NH-L9a-AM4
1 DAN Cases A4-SFX V4 black, Mini-ITX (A4SFXV4-B)
1 Corsair SF Series SF450 80 PLUS Platinum 450W SFX12V (CP-9020181-EU)
Mainboard would be recommended by Dan I think he means that USB 3.1 Gen 2 works on the frontusb ? Find the price salted anyway.
ASRock B550M-ITX/ac also supplies 300 A at CPU Mosfets and has current chipset for 130 Euro.
Undecided.
SSD I have chosen a cheaper one.
Ram stay fix the 32 gb. horizon zero dawn needs 25 gb Ram and that will not get less.
2 case fans for better temps in the case
Power supply should be able to handle it.
Would you change anything? I notice when the graphics card is on it, I am going to blow my budget by far :/
