DAN A4-SFX
xredlinexx1
29
Has anyone used an hdplex 200w dc-atx coupled with a kmkpt Dynamo 360 to save space? Do you think the Dynamo 360 could be squeezed in somewhere like below the GPU or above? I'm thinking of ways to maximize space for a small custom loop.
guniens
33
@kiehl: Just use a Noctua L9a and in Ryzen Master Software or UEFI you setup 65W ECO mode for it. This will only result in a lower boost if all 12 cores under heave load. A nice bonus is that your CPU will run much more efficient and much cooler:
Here is a review of a 3900X none X only for OEM (basicly a 3900X in ECO mode): https://www.tomshardware.com/reviews/amd-ryzen-9-3900-review-eco-mode
Hi
I'm running a ryzen 7 3700x at stock settings with a l9a + fan duct.
Played 1 hour GTA V, case closed, max temp was 70°c (maybe 72°c).
Is it good? Thanks in advance!
guniens
33
Yes this is good.
Thanks.
Another 2 questions:
  • i've routed the riser behind the gpu and not behind motherboard since i've a second m.2 on back of motherboard for my games. Just m.2 no pad nothing and reaches 50°c during gaming. Is the route of riser and m.2 temp fine?
  • you have a 3700x with l9a + fan duct. Have you set custom settings in bios?
Thanks!
Dawelio
120
75
Yes this is good.
Hey Dan,
I have 2 questions for you;
1. How come the V3 came with a black PCI-E riser and the V4.1 comes with a non-black one?... Seems like a bit of an odd move going forward with the entire case and innovating, but going backwards with a single component inside. Which you now have thoughts about fixing with an V4.2 revision.
2. Is it possible to get a black PCI-E riser separately for the V4.1?...
Thank you.
sancho
240
135
Hey Dan,
Thank you.
I am not Dan but I will answer
Reactions: Dawelio
Shrink Way Wielder
1,632
1,599
Hey Dan,
Thank you.
It is no longer black because the current riser cable is the only PCI 4.0 cable currently available. I am guessing dondan will switch to black when they become available.
Reactions: Dawelio
dondan
1,043
3,306
@guniens
1) This is not a problem
2) I use these values: 0-70°C = 30% fan speed, 70-85°C = 60%, 85+°C = 100%
@Dawelio
1) The 3M riser is used in the v4.1 (silver color) it is the only available PCIe gen4 riser.
A4-Changelog https://dan-cases.com/dana4_spec.html
  • 3M™ 8KC3-0726-0300 PCIe® x16 Gen4 riser
  • USB 3.2 gen2 Type-C front port with internal Key-A
  • ADT R33UF-TU PCIe® x16 Gen3 riser
  • USB 3.2 gen1 Type-C front port
  • 92mm fan mount point under the motherboard
  • Pre-drilled threads for custom window kits
  • The 120mm AIO bracket is now optional
  • Lian Li PCIe® x16 Gen3 riser (black PCB and cabes)
  • Adjustments to the USB3.0 internal cable to be compatible with Asetek® 92mm AIO
  • Improvements to the power button to optimise the pressure point
  • Adding mount points for HDPLEX 400W HiFi DC-ATX
  • Mounting bracket for 120mm AIO
  • Cover for GPU mount area
  • Better alignment of USB port
  • Stamp-in motherboard stand-offs
  • 92mm fan or AIO mount point
  • Rubber case feet with better grip
  • Kensington Lock
2) Just buy a black gen3 riser from LINKUP, ADT, LiHeat, Silverstone, Thermaltake s.o.
Reactions: guniens
xredlinexx1
29
Whats the exact clearance above the motherboard to the top of case, ignoring the riser cable? Also, how about below the motherboard? Thanks!
Dawelio
120
75
@Dawelio
Well after doing some research, that is not as easy as it sounds unfortunately.
The riser in the Dan case has a straight up PCI-E slot, as shown in the picture:
All the risers are 90 degree angled on the end, so if you would attach it to the case, the GPU would then be oriented like in an tower case and not upright.
ExplodingWaffle101
114
69
look harder :) LINKUP, ADT and liheat at least certainly have the compatible risers. I think the right angle ones are more commonly "mainstream" because they're used in vertical GPU mounts.
Kozi
What Is the pro
@beejayone Thanks! Your build is based on the 120 mm AIO on the side, though!
I thought the comment was refering to the position of the AIO in the 92 mm asetek 645 LT video. But since he did the video on the 120 mm AIO as well, maybe Dan's comment referred to that solution!
I am struggling with a corsair sf600 and a 92 mm aio asetek 645 LT. Since the guy selling custom wires for the dan case doesn't take orders these days, I try to work with the original wires.
I like the case a lot though :-)
what Is the problem with making your own cables?
thelaughingman
31
Finally ordered the 4.1, has to be silver since black is out of stock but I just can't wait any longer. hopefully it will arrive around my birthday (end of March). Have everything on hand ready to be built :)
RaihaX
29
If its from OCUK it took 3 days to get to AUS so you would be fine :D
