DAN A4-SFX
RaihaX
In my case, chassis and CPU fan speeds are controlled by fan curves set in the BIOS.
Yeah same with mine - i even put mine on the "silent" mode (B450 Aorus) and is never that low so I was just wondering if I need to reseat my cooler, but i rather not unless I know for sure.
Dawelio
90
69
I am currently starting to build a system with two 2080ti water-cooled in a dan a4 package, this is the second such system I have assembled. In it, you will see how to install the power supply correctly, because no one installed it in this case. And also see how you can integrate a 240mm radiator in this case
As much as that would be nice to achieve, cooling those two 2080TI's in the Dan A4 case will be... well... impossible.
First off, you can only have a single 92mm rad inside of the case, with a slim fan. And having that little radiator space to cool 2 high TDP GPUs, won't be possible.
Sorry, but I think you'll run into more problem than what it is worth really.
But my hat off to you sir, if you do actually manage to pull it off.
fabio
854
923
Well, it is not finished yet, but maybe will be possible! 😁
Reactions: Dawelio
Dawelio
90
69
Now that is a small, cramped, SFF build right there! How you even manage to work inside of all of that, is beyond me. But kudos to you dude!
sancho
143
55
Thank you all for your attention and interest. The process is nearing its end with only 2080 ti, but with a radiator 360x120 (for the sake of experiment, that this is possible). Next week comes the second 2080 ti, motherboard and connectors for wiring. Today I installed all the fittings and tubes (there is still a lot of space left). Soon report
TunnelVision
Even "silent" ramps up fairly early on (maybe that's a good thing). Creating your own curve will tell you what temperature you get at low rpms.
kiehl
Feb 23, 2020
Hi Guys,
I just ordered dan 4.1 from ocuk. I got 3900x and Gigabyte GeForce RTX 2060 6 GB MINI ITX (170mil) from my old build.
My plan is to cool ryzen with Alphacool Eisbaer LT120 to mount it on a bracket next to rtx. Now first question - will it fit? can't find any info about this aio in dan 4 case. Also then i'm planning to add another 120rad under psu and connect everything with quick connection pipes as pump is the same as it is for 240 version.
Any advices if my plan is possible ?(under psu 120mil rad won't wont fit so 92mil will i'm assuming)
Dawelio
90
69
Hi Guys,
This will be a very tight fit, if at all dude. That AIO also seems to have rather thick tubes, which may make them very hard to route inside the case, which is already compact as it is.
Reactions: kiehl
RaihaX
Yeah I ended up using a manual curve, will keep an eye on temp to see how I go, realise the bulk of the noise was mostly my chassis fan anyway so i crank that way down 27% until temp gets real high (figure this will be just as good if you had no fans!)
Still got to swap my fans on the Zotac Mini as well as that is stuck at 37% so a fair bit of noise (tried the bios flash and got my memory locked issue)
sancho
143
55
Hi Guys,
It’s impossible to put two radiators (you need to change the location of the power supply) .120 mm radiator has a height of 150 mm (expansion tank)
Plus fitting height
