DAN A4-SFX
Insanity
8 more days :c - next time imma order it from SFFLabs the waiting time on Caseking kills my mood day by day.
I dont understand why EU is always coming in last.
Reactions: Kozi
guniens
23
1) For this config you do not need a case fan. But I would setup them push out.
2) The default fan on the BlackRidge is not very silent, so better use a Noctua A9x14. http://glob3trotters.com/portfolio/alpenfohn-black-ridge-best-low-profile-air-cooler/ For the best noise and temp scenario I would use an Noctua L9a with 3D printed fan duct.
First of all thanks!
1) Isn't always better to have fans / shouldn't always lower temps? by "push out" you mean exhaust?
2) You're suggesting to go with L9a with fan duct? Is it better than black ridge?
I'm more interested about temps instead of noise.
Thanks in advance.
dondan
DAN Cases
935
2,931
1) It will not change that much. Yes exhaust.
2) Here are the best air heatsinks sort by performance:
  • Blackridge with A12x15 + VLP Ram
  • Thermalright AXP90 Copper
  • Noctual L9a + Fan Duct
  • Cryorig C7G + Noctua A9x14
  • Blackridge with A9x14
  • Noctua L9a without Fan Duct
Reactions: Tashi and Weredawg
guniens
23
Thanks.
Performance means also lower temps or just lower noice? If lower temps i will go L9a with Fan Duct.
Should i change fan if i go with L9a? I would buy the chromax version in case.
dondan
DAN Cases
935
2,931
Yes this means lower temps. You only need to change the fan if you does not like the color.
Reactions: guniens
sancho
97
@dondan Okay thanks, and I know this has been over a million times before but the preferred setup is intake at the bottom with the AIO and exhaust with an air cooler? I really don't want to go through the hassle of taking it all the bits again and flipping fans about.
EDIT: Just did the BIOS setting and it has certainly helped - still at almost 80c in games however - maybe I just did crap with the silicon lottery
In your case, do the following
1. Remove the thermal cover from the processor and replace the thermal grease on the bottom with liquid metal (this will give you -20c) it is easy to remove; you need to use a thin stationery knife not to cut through the sealant deeply; there are many videos on YouTube. This applies only to the 8000 series
2. coolers only !!! on blowing, it is advisable to install above the raiser under the video card.
guniens
23
Can i use also Noctua L9i? Because L9a isn't available in chromax black
dondan
DAN Cases
935
2,931
@guniens: You can buy the chromax fan separately or you need the AM4 mounting kit for L9i (i=Intel). But keep in mind the L9i perform not as good as the L9a (diff is 5-7°C). Do you have a window kit or why do you like to wrap the silver 3M cables? But to answer your question yes you can wrap it.
guniens
23
Thanks. I will go with L9a, i saw on reddit that there will be a chromax version too like the L9i
No window kit, i just don't like it silver 😅😂
Misjn
Nice to see they got them some days earlier even. Think the 22nd was the "expected" date.
Had my pc running in a cardboard box on my desk for like a month just waiting for the case :)
Insanity
Let me summarize my experience so far, first of all im a Experienced Builder (when it comes to Mid and Big Towers),
This Case is a breeze to build in, the only part where I had trouble was with the PCI-E Riser (more specific bending them), im not familiar with them, so I obviously went on it with probably to much caution (not saying you should go ham on them), better safe then sorry i thought.
I also realised that cable management in such a tiny room takes up a good anmount of time.
And I found out that If you remove the shroud from the AMD Wraith Stealth Cooler that comes some of the lower end AMD CPU's (like my R5 3600) it actually fits the Dan A4 quite good. (Also smh removing the shroud does lower the noise but increase the temps by a tiny anmount).
Some general tips for others:
If you wanna install a fan under the Mainboard Area, remove the Power Extension and PCI-E Riser first, its much easier that way.
Building in the following order was hassle free and fast for me: (Fans/SSD Drives) -> GPU -> Mainboard -> PSU
Reactions: SiKiaTriK
Mandalorian
Got my Case today :3 but cant close mainboard side panel yet cause they didnt had black ridge in stock.
i got bundle with black ridge, still considering to swap it for Asetek 645LT or Corsair H55 (itx gpu). 120mm AIO look easier to install, but my SF750 gets quite warm (fan kick in at 300w) and there is not much clearance between PSU and 120mm AIO mounting bracket, which could results in worse performance.
Optimum Tech confirmed lower temp with 645LT in his video. Cant wait to order custom PSU cables, even with Corsair braided cables its a mess.
