DAN A4-SFX v4.1
kroken
65
Okay i plan to use latest 4.1 A4-SFX with 645LT, what fans should i add in the case? i will use one 2500 RPM a9x14 for the AIO.
Slegg
Dec 15, 2019
I received my case today the v4.1. (BTW awesome case good job dan). The riser cable is silver (it isn't a massive problem). Is it a feature of the v4.1 because the riser was changed to gen 4?
dondan
DAN Cases
1,977
8,378
@Mandalorian
SFFLab: They already have stock but they are offline because of shop changes and new year holidays.
Caseking/OverclockersUK: Will have the cases in the next 2-3 weeks.
Dirac: They have stock but only available in Japan.
Reactions: PHE
seppola
34
looking into building a setup with this case. Excluding AIO, It seems Alpenfohn CPU cooler is king (+120mm fan), few questions:
  1. Is there any x570 board that works well with the cooler
  2. Would corsair LPX work?
Thanks,
2,601
2,715
Thanks,
Take a look at the last couple pages of this thread, deals with VLP memory.
Bowspin
27
Received my case from Dec 27th batch! I'm so happy right now but I have to wait 2 more days for my gpu to arrive.
One thing though I noticed that my riser is really tightly bent, I'm not really worried but anyone can confirm that this is completely normal? Thanks :p
sling
Planning to use a 3d printing service to print the fan mount and just have a couple of questions:
1) does it matter what kind of plastic is used? I.e. PETG vs PLA
2) how do I mount the fan duct to the L9a?
Seperately, I'm running a ryzen 2600 stock @ -0.1v offset. Idle temps are in the low 40s (ambient temp is ~30c). Does that seem normal? Wondering if I should try and reapply the thermal paste cos it was a bit awkward first time I applied it. Thanks!
Bowspin
27
Hey guys, I just finished my dan build and I am very worried... My cpu idle temps are around 50~60° with the case open, I launch a stress test which quickly put it to 90 so I shut it down
It's my 4th pc build and I don't know what went wrong, the fans are spinning, I applied a regular amount of thermal paste, my noctua l9a is well seated (I even went to check a mounting video in case I messed up somewhere but I did everything like other people did)
I don't know where I messed up and I'm scared of spending a lot of time in rebuilding everything to see nothing change, especially because I would just redo the same as it looks I did everything I should have done..
I will soon try to launch a game and see...
My gpu (5700 power dragon) is around 47 idle and my NVMe is 29 which sounds okay.
I'm with a ryzen 5 3600, Asus rog strix b450-i, noctua l9a.
Any idea of something I overlooked before I rebuild everything? Thanks in advance...
EDIT : update, I tried playing kingdom come delivrance in highest possible settings, apparently my cpu didn't go over 75° and even weirder my gpu didn't go above 59... I don't get it
