DAN A4-SFX
FranchuT
@dondan
Zotac GeForce juego RTX 2080 Super AMP
Zotac GeForce juego RTX 2080 Super Doble Ventilador
Juego EVGA GeForce RTX 2080 Super Negro
EVGA GeForce RTX 2080 Super XC juego
Inno3D GeForce RTX 2080 Super juego OC X3
ASUS Turbo GeForce RTX 2080 Super Evo
Nvidia GeForce RTX 2080 SUPER FE
¿Qué gpu recomiendas? temperatura y ruido? tengo rtx 2070 super evga xc y tiene bobina quejumbrosa
vi rtx 2080 super ventus msi es compatible?
Vilmir
"I only gained about 30-35%"
duh, you saying this as if its nothing, this a huge gain.
Sure it is already significant, but I upgrade my GPUs rarely, I skip a generation in general, so I am more used to 70-100% upgrade in my games :)
Reactions: Mako
longmd
I'm looking at getting a fan duct 3D printed online for use on the Noctua L9i cooler, but I've read that some materials are better than others in high-heat applications (like attached to a CPU heatsink). I currently run an i5-6500 (65W TDP), so nothing crazy, but I want to make sure it wouldn't get hot enough to start affecting the plastic of the fan duct. Has anyone had a duct made that can chime in about the best materials?
The site I'm looking at has the following options: PLA, ABS, Nylon, TPU, and PETG.
Khanza
Hi, anyone know the estimate shipping date for asetek outside USA (asia)
There is no shipping date in sfflab website
Slegg
Dec 15, 2019
Hello i'm choosing a gpu for the dan case a4 v4.1
Is the gigabyte rtx 2060 super gaming oc fitting in this case its L=280.35 W=116.45 H=40.24 mm ?
PHE
You can use the following link, to check it out: (answer: yes, it fits)
The_Mad_Madman
108
As far as I can see there is no issue placing the X570i AORUS in the Dan, as no one has complained of it.
v4.1 has a PCIe Gen4 right? There would be no issue using a 5700XT and for "future-proofing". As the x570i Aorus has no use for the new front usb can you order a case without it? Will something new for that will be thought for v4.2 (5?).
Usually how long does it take for a new revision?
Vilmir
what is better for dan a4? Rtx 2070 super ventus oc or gigabyte rtx 2070 super windforce oc ?
I have the Ventus and it is great, once I tweaked the fan curve, but apparently the Windforce is the absolute best option
The Ventus was cheaper for me.
riba2233
SFF Time
625
1,026
www.sfftime.com
In terms of acoustics or performance? If performance : what's the card you'd recommend in the 2060S/2070/2070S range for an A4 if going for silence above all?
In cooling performance (fps will be the same), it has vertical fins (will exhaust hot air much better) and three fans. I would chose that model for everything mentioned above, I don't think there's better model that fits into this case.
Tashi
33
I was checking DAN builds on PCPartPicker the other day and found person using a Noctua NF-A9 on their NH-L9a cooler. I was wondering if anyone here has tried doing that and how it performs.
Here is an image of their fan and cooler inside the case
